Headlight uprate limitations???
Solved running light problem...
fuel pressure question
In the past I have had problems with other vehicle when upgrading the existing headlight system to halogens. Does Dodge have any limits as to how high a wattage you can install before perhpas kicking a fuse/breaker/relay etc. ??
I was thinking of going up to 100/150 halogens. Will these 'overdraw' the system??
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar, Dual Shock Front Stabilizer, BD Injectors, 3" Mandrel bent exhaust, 16cm 'Hot End', Modest Pump Tweaks/Timed, K&N Air, Isspro Pyro,Tach,transmission Temp, Auto Meter Oil Filled
Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-75R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine, 12,000 lb. Warn Winch, KC Spots.
97,000 Kms.
Actually the stock lighting system overloads the system, the headlight switch is the weak link, if your going up i wattage you'll need to add a relay system, pull the headlight voltage directly from the alternator and just use the existing wiring to activate new relays, doing this alone with improve hedlight performance 100%, jacobs electronics sold a kit they called a headlight britener that used heavy duty relays, but i think i heard hear from some one that they no longer make the product you might want to check with them, i been sing there kit for years and love it, along with a set of halogen extra visions it's all the light i need, try www.jacobselectronics.com
93 W 250, Banks,B&D,K&N,JRE,Rickson 19. 5's,FourWheel camper. <A HREF="http://rducsh.homestead.com/truck.html" TARGET=_blank>
Truck Spec Site</A>
<A HREF="http://albums.photopoint.com/j/AlbumList?u=279120&Auth=false" TARGET=_blank>
Photo Site</A>
The switch is the weak link. My 80W make the switch a little warm, I have to install an off-road wire harness to the lights with the appropriate relays #ad
. The wires to the headlights are puny and most likely couldn't handle the 100w or 150w per bulb.
Jeh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs. 232,500 miles (372,000 Kms) 7700 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics
About 7 years ago I installed a Bosch Halogen upgrade kit. It uses H4 lamps that fit into a dummy sealed beam unit. Have not had any problems so far, not even had to replace a lamp yet. Don't know how much current they draw, haven't had any reason to measure it. The illumination level is much better than the stock sealed beams.
Neil
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): &lt;bombedcummins@sympatico. ca&gt; (link at top is work adress)
I hear a lot of talk about the headlight switches going out on these trucks. I have not had any problems with mine - yet. I've been running halogen sealed beams for five years now, without any problems, but then again, the rest of the truck isn't lit up like a Christmas tree like some of the rigs I've seen. Does anyone know if the stock headlight circuit uses a relay for the lights? If not, it would probably be a good idea to wire one in.
89 D-250 LE 5 speed 3. 55 Limited slip, K&N, straight piped, Boost/Pyro. & 16cm2 215K and still going. 91 W-250 5 speed, 4. 10 Limited slip, 16cm2, 6" Skyjacker lift, RS9000, Dump bed, 18K original mi.
