when I first start my truck the headlights will flicker and sometimes the voltmeter will pulse a little. I noticed that my passenger side positive battery terminal was a little loose and had some leakage from the battery. so I cleaned it and sprayed a protective sealant on it and tightened the terminal. The headlights stopped flickering but it came back a week later. I again checked the terminal and it was still clean and tight . any suggestions?also if I WEREto replace the batteries what batteries do you all suggest?
