AEdelheit
Hoping to get some insight here that I have not been able to find searching the internet on an odd problem my truck has.
2006 2500 with halogen headlights, no LED or HID. While driving the headlights will randomly flicker for a fraction of a second or sometimes turn off for a good second or two then turn back on, both headlights do it at the same time so its not the typical TIPM one headlight not working and its usually on smooth roads nothing rough.
I can not duplicate it with the truck parked, even leaving the headlights on for an hour straight doesn't seem to make them act up so I have had to replace some parts without properly diagnosing the problem. The TIPM, Multi-function switch, headlight switch and headlamps have been replaced and no change. The fog lights are not effected and if the brights are on it will still flicker or turn off. I have pulled the cluster, checked all connections and grounds between the headlights, TIPM, cluster and switch as well as wiggling every wire and connector I could find with not a single flicker or dim of the headlights, everything looks clean and tight so I dont think it is a bad connection or broken wire. No other odd electrical issues anywhere on the truck.
Looking at the service manual the headlight switch gets its signal from the cluster then sends the command back to the cluster , the cluster then sends it to the TIPM via Can Bus, I highly doubt its a Can Bus issue as there are no other problems so I am leaning towards an issue with the cluster but have never heard of a cluster causing head light issues and could not find any issues like it searching online so that part is odd.
Anyone ever heard of or dealt with a similar issue before?
Thanks in advance.
Thanks in advance.
