I'm not sure if it is the same type of problem I recently had with mine. Check your day time running light module. If its hot, it may have died. To confirm this, you can unplug the module. It is a black box on your driver side fender under the brake cylinder (it is about 2"x4"x1. 5"thick) You will loose your high beam dash light when its unplugged. Your night time lights will still work, just no day time running lights.
If its the problem, its about a $100 fix
