Heat Blend door cable.
93 starter relay part number
I need the AC evaporator and heater core for my 1993 D250
I'm trying to find the cable that goes from the heat selector lever in the dash to the door behind the dash. Mine is hung up and has to be moved with a pliars.
Thanks guys! Loving my first gen!
When my cables would get sticky like yours I would always take them out and spray them out with WD-40. Just keep working the cable back-and-forth as you spray WD-40 it should lead out all the dirt and rust. You can also coil it up in a coffee can and let it soak overnight with any thin oil.
