Heated Seat Problem - Need Help
Good and the Bad
Removing Body Side Moldings?
2001 2500 - LED on driver's side only flashes when switched on and seat does not heat. LED on passenger seat stays solid and seat does heat.
Anyone had this problem?
If so, what was the problem and the solution?
Thanks.
Hey Jumbojet,
I can only tell you that the 'flashing' indicates a problem with the heating system on that side. Have you checked the connections under the seat? There is also a
relay for the heat but since I sent my service manual back I don't have the location but I believe it's in the small fuse panel at the left end of the dash.
Mick2500
<font color=blue>
2001. 5 2500 ETH/DEE, QuadCab, 4X4, SB, LSD, 3. 54, SLT+, Sport, Intense Blue PC/Agate, Tow Package, Camper Package, 'DC' Bed Cover, Sliding rear window. Totally STOCK!!
On Order 4/28/00
Arrived 9/14/00 !!
[This message has been edited by Mick2500 (edited 10-09-2000). ]
