Details here: TDR Privileges
The low speed on my heater blower (01 2500) quit, all the higher speeds work as they are supposed to. I suspect it is the resistor if so equipped, does any one know if it has a resistor and how to access same?
(1) Disconnect and isolate the battery negative cable. (2) Reach under the passenger side end of the HVAC housing and unplug the wire harness connector from the blower motor resistor. (3) Remove the screws that secure the blower motor resistor to the HVAC housing. (4) Remove the blower motor resistor from the HVAC housing.
You are looking at P/N 04720278 RESISTOR, Blower Motor
