My 01 2500 vent system goes from normal air (or a/c) to full hot randomly (I think). It usually returns to the cold position but not always right away. This is not cool when it's 100 degrees outside. When I do need heat, the heat control works but is either full on or full off. No in between setting can be obtained.
I've read quite a bit about the blend door motor system and most problems people are having are with the blend door failing in either extreme position. Not randomly switching back and forth.
Could this be a variable voltage problem? My first instinct was to blame a vacuum line but vacuum doesn't control the blend door.
Any help would be great!
Thanks,
Darren
Thanks,
Darren
