I think this one ranks as the "back surgery' of our trucks. There is no easy approach to get it out. The heater boxes are one-piece, unlike import trucks. Once you have the dash pulled up or removed you gotta find all the anchors to the firewall and remove, separate the A/C lines, the heater hoses, the vacuum control lines and the temperature (blend door) cable, then the thingy should come right out!! For the work involved you might wanta replace the evaporator at the same time. Check it real good - any sediment from sucking dirt/leaves down the heater duct will eventually rot the evaporator. When you open the heaterbox, clean it well, check the condensate drain port. Reassemble and 'bench test' all the dampers before reinstall - they like to pop out of place!!. To reinstall, reverse the prior 2 days work!! Good luck.
