2nd Gen Non-Engine/Transmission heater core
2nd Gen Non-Engine/Transmission Rear Axle Seal Replaced by Dealer
Engine/Transmission (1998.5 - 2002) quadzilla v.s. edge
Could the heater core leak so little that it would not leak into the cab and get the floor wet, but enough to make the windows fog up? Every morning when I leave and turn on the defrost the windows start to fog up and it takes about 20 min for it to start to go away. I just had the heater core replaced a year ago, but what else could it be?
thanks,
Cory
The quick answer is yes. But, if you are running with A/C the night before when you shut the truck down, or if you are in a rainy area and are using defrost the night before, you can get an accumulation of moisture on the evaporator that will take a bit in the morning to clear up. If you turn back to defrost it should clear up in about a minute or so. If its not doing that, is your A/C working properly (assuming you have a/c), or you might have a leak in the system, or elsewhere in the truck. Is your carpet wet anywhere?
mine has been leaking for 18 mos! A/C isnt working and I can just barely smell coolant but no wet spots anywhere!
the carpet is not getting wet like it did last time, it seems like when I first turn on the defrost it has a little bit of the anti-freeze smell, but wouldn't the carpet be getting wet? I had the A/C on the other day when it was up around 80 degrees and it seemed to be okay.
This is why when I'm done running the A/C, I turn the control to "Vent" and let it run, until I start getting warm air running through. It helps the evaporator get rid of that moisture build-up. It also helps eliminate that musty smell which, IIRC, there was a TSB for... . Mopar tech would spray a solution of bleach and water into the vent intake and it would get rid of the smell.
Try turning it to vent and see if that works.
How did my name come up in this?
TSB:24-006-06
SUBJECT:
A/C Cooling Coil Odor
OVERVIEW:
This bulletin involves inspecting for leaves and other foreign material, cleaning, and
treating the cooling coil and housing.
MODELS:
1995 - 2003 (AB) Ram Van/Wagon
1995 - 2004 (AN) Dakota
2004 - **2007** (CS) Pacifica
1998 - 2003 (DN) Durango
2002 - **2007** (DR/DH/D1) Ram Pickup
2004 - **2007** (HB) Durango
2001 - 2006 (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan
2002 - **2007** (KJ) Liberty
1993 - 2004 (LH) 300M/Concorde/LHS/New Yorker/Intrepid/Vision
2005 - **2007** (LX) 300/**Charger**/Magnum
2005 - **2007** (ND) Dakota
2002 (PG) PT Cruiser (International Markets)
1995 - 2005 (PL) Neon/SX 2. 0
2001 - **2007** (PT) Chrysler PT Cruiser
2001 - **2007** (RG) Chrysler Voyager (International Markets)
2001 - **2007** (RS) Town & Country/Caravan/Voyager
2001 - 2005 (ST) Sebring Coupe/Stratus Coupe
1997 - 2006 (TJ) Wrangler
NUMBER: 24-006-06
GROUP: Heating & A/C
DATE: August 9, 2006
2002 - 2006 (VA) Sprinter
1999 - 2004 (WJ/WG) Grand Cherokee
2005 - **2007** (WK/WH) Grand Cherokee
2006 - **2007** (XK**/XH)** Commander
SYMPTOM/CONDITION:
Some vehicle operators may experience a musty odor from the A/C system, primarily at
start up in hot and humid climates. This odor may be the result of microbial growth on the
cooling coil. During normal A/C system operation, condensation forms in and around the
A/C cooling coil. When airborne pollutants mix with this condensation, bacteria and fungi
growth begins and odor results.
DIAGNOSIS:
If the operator describes, or the technician experiences a musty odor when operating the
A/C system, perform the appropriate Repair Procedure based on the vehicle model.
