It's a fun job, change the a/c evap core too while your inside!
Most shops charge at least 8 hrs to do this. After you've changed a few the speed picks up a bit and you can beat the flat rate. If you have a "birds nest" of wiring from aftermarket alarms, sloppy gauge installs etc. plan on some extra time.
Get the applicable FSM to guide you along.
You will need an a/c vacuum pump, and manifold gauges to evacuate the a/c system when you are finished and then recharge the system with 134A . You will also need some 100-150 visc. oil to replace the oil that was in the components changed. Now's a great time to do a coolant system service.
I always change the accumulator/dryer to. Aftermarket components are available, but the DC units fit best. . read $300 +/- for the evap core, htr. core and accumulator.
Good luck
Andy
