Engine/Transmission (1998.5 - 2002) Heater grid -which battery?
2nd Gen Non-Engine/Transmission Need help with tailgate decal location
2nd Gen Non-Engine/Transmission Front Driveshaft Loop Kit
If you plug in the block heater a few hours before starting the engine, the grid heaters don't put near the load on the batteries and charging system. Just have to plan ahead to plug in the truck before use as much as you can. It not difficult.
Better yet, bypass the PCM and put the relays neg posts on a toggle or momentary switch. Once the engine is running it doesn't need the grids to cycle. Does away with the annoying dimming headlights.
Did that very thing 23 years ago. Hardly ever use the grid heaters, but it's nice when I do.
- John
Not sure what year this started = at 15mph (or was it 1500rpm) grid heater circuit disengages, at least that's what I remembered 99 doing. Obviously once engine up to temp they're not running.
