As long as I have owned my truck, the heater grids cycle when the outside temperature is precisely 66-degrees and below (with a cold engine) just as the factory manual states. However, for the last several days, we've had temperatures down to 57-degrees and the grid heaters are no longer cycling on! Am I being paranoid or could this mean that my IAT sensor is on its way out?
Additionally, if you guys are noticing such improvements with new IAT sensors (power, fuel mileage, etc. ), why has an "IAT out of tolerance" trip code not been set? At what point would it set? Wouldn't the MAP sensor be just as critical since volume is calculated by both pressure and temperature by the ECM?
