Hello,
I have been having a wierd problem and I am unsure what to check next. The engine temps are going up to 230 or 240 and I am then losing heat inside. The engine temps drop back down to 180 (180 thermostat) and heat is back in the cab. I know this normally indicates a bad thermostat. I have put three different ones in, all with the same result. I put the same thermostats in my brothers truck and everything works as it should. If I had normal engine temsp but no heat I would suspect the heater core, could that still be my problem? If not can anyone suggest any other ideas?
Thanks in advance for any help you can offer.
