If the evaporator core is icing up, it's an A/C problem. I think it's caused by low refrigerant, but I am not certain - not being an A/C technician.
Get your A/C serviced and the problem will go away.
That being said ... if air comes out only one place no matter where you turn the control knob, then it's probably a vacuum hose problem. if a vacuum hose is leaking, then none of the actuators will work to redirect the air.
