jaynes-
I'd second the t-stat idea. I've had a few stick open, but cardboard helped till I got around to replacing it. If you're only getting up to the line between the C and the first line, you're running WAY too cold. All of mine have run on or aroudn the second line that is connected in the sweep. Get a 185deg unit from Cummins, and change it out. i had a fan clutch crapout on me- came unbolted from the fan clutch- and I took it off on the side of I25. Drove that way for 3 weeks, loaded and empty, no problem.
AS for your turbo, I'd say yes, the PDR 35-16 would be a good upgrade. Give you a decent bottom end, yet free flowing enough to do ok down the highway. See my reader's rig for pics of a HX35 on a non-IC engine. The outer hose is 2-3/4" silicone turbo hose. Kind of pricey, but it stretches and will go with some PB Blaster to help out. Any questions, PM or email me.
prototech-
If your turbo is stock, it is a H1C, came with a 21cm housing. It is good for about 25-28psi boost, then starts to loose effeciency- drive pressure is greater than the boost you get from it, and the additional air is hotter than at lower pressures. An HX35 looks real similar, but is good to about 33-35 psi boost. The exhaust housings interchange; turbo drain bolts up, and the intake hose fits right on there. There should be a tag on the front of it, close to where it flares out to go to the intercooler elbow. Should have an assembly#, type (H1C), and a serial number (?)
