Well the H. D. 2nd gear strut can be bent. That is why I lost 2nd gear. We took an early model thicker hardened strut and welded it to the H. D. struc with the side flanges for an exhra H. D. strut. What,s next?
Upon returning from a test run, Larry the owner of Bellflower Trans. found water leaking from the head gasket between #1 and #2 cylinders exhaust outlets, and is running down the block at #3 cylinder. I can's see any cracks. I will use some sealer tomorrow and see what happens.
Bruce
Bruce
