I was able to figure out how to remove the linkage rod last night, it actually just snaps on to a ball joint.
I lifted the lever up a few inches higher and wired it to stay in place, what a big difference in my braking. Oo. The truck stops twice as good now and the antilock still kicks in upon a panic brake. No more stress for the front discs!
What gets me is that my 97 shop manual has no mention of this rear load sensing valve being in the truck. As far as the manual is concerned it doesn't exist. I have tried everything since I bought the truck new to try and take some load off of the front brakes and was to the point that I figured there wasn't much I could do about it.
I only stumbled across this TSB because I was searching through pages about brakes on the TDR just to see how many other people felt like I do about how fast the fronts wear out.
I was convinced that my rear brakes weren't doing anything but couldn't figure out why. I have the larger rear wheel cylinders and adjusted the rear shoes but they still didn't do their job.
I am going to put in the bypass hose that the TSB calls out. If the brakes get too sensitive I will make an adjustable link or some sort of plate that I can adjust the valve with.
BTW, some people are concerned about the fact that the TSB states you must be using at least 75% of the GVWR (8800 lbs. ), like someone else posted, my truck weighs 6700 lbs, 6600 is 75% of 8800, I also have the Rancho shocks which lifted my truck about 1" or so and the TSB says that altered height will affect the valve.
Chris, it's located right above the axle just behind the drivers side wheel. There is a rubber hose that connects to a tee at the axle housing, follow the hose back up towards the bottom of the bed and you should see a little mechanism with a rod that connects down below the axle. Some trucks don't have it, if you have a 96-98 2500 4x4 with Cummins and it is 8800 GVWR more than likely you have it. Let me know if you can't find it, I have a diagram that shows it real clear.
