Here's the background: 99 2500 4X4 QC 47k mi. Ran great in 4wd and 2wd.
Installed the Skyjacker D25 front coils and rear add a leaf. This is a leveling kit, which raises front 2-2. 5 in and rear about an inch. (no control arm replacement). Took to dealer for alignment. Drives great (hadn't put into 4wd). Well winter has come and when I put it in 4wd I get a vibration starting at 25 mph. This does not happen in 2wd. All I can think is that the ujoint is having some problems due to caster. How do you check to determine if ujoints are bad? Any other thoughts are welcome.
thanks
koredish
thanks
koredish
