Help 911
Diablo downloader and puck combo
07' 6.7L specs & prices from DC
My 03 is having issues.
With the Edge hooked up (on stock since it's a new motor) the engine wouldn't make enough power to get out of 3rd, and was running very rough. My egt's would climb to 1200 f. The codes were P0336 Crankshaft Position Sensor Performance, and P2146 Fuel Injector Group 1 Supply Voltage Circuit.
I unhooked the Edge and my egt's returned to normal, but the truck is still running rough, but makes power. Before the test drive I checked the codes again (after several starts) and P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1, came up, but the 1st 2 were gone. After the test drive (had decent power but I could feel it bucking once in a while) the 1st 2 codes came back.
So I have 2146, 0336, and 0500 codes. Some times the truck fires right up, and others it takes a couple revolutions. If I'm just sitting there and stab the throttle it will rev up smoothly at times and others it bucks.
What the heck is going on, if I can't figure out the issues there's no way I'll take this truck out to work, as I can be up to 400km from civilization.
Carl
