Details here: TDR Privileges
I am told the heat gun method works. I tried it a number of times and it proves nothing. You may very well loosen one at a time. The best method is old school. Pull them all and check them on the bench w/a pop tester. Or have a shop perform this.
Well I narrowed it down to the #6 cylinder. When I loosened the #6 line, the noise went away. I swapped the #1 and #6 injectors with no change.
It doesn't sound like a rod knock, it's like that cylinder is just louder than the others but all is quiet and smooth at higher rpm's.
I think I'd take them to a shop that can reset them to the correct pop-off pressure. It sure sounds like the one you identified is popping at a lower pressure than the others.
