96 ex cab, gushing fuel just above the starter almost a mist type of spray but heavy enough to soak starter and block. What usually breaks in this area I can't actually see where the leak is. I had the tank out to replace the fuel Mod. a month ago. Do the lines rust out as well. If I need to replace the lines does the tank have to drop again. .
Thanks guys sure could use some advise on this one
raz
raz
