I've just posted this in the HELP forum - I'm posting it here to get a fast response as well.
I've justed started working on installing a Painless wiring harness to add some accessories. I first disconnected a High power fuse for my Amplifiers, I then went to disconnect the battery, while I was doing this the pigtail for the amplifier fuse came in contact with the brakeline. It sparked as expected but upon inspection I arc-welded through it and it started seeping brake fluid.
I'm in trouble here guys. I can't drive it and I need to order a new brake line. Luckily It's a short one and not one that goes to the brakes. There is one thing I am not comfortable working on is brakes. It's also 4th of July weekend so time is of the essence.
I posted pics. The screwdriver is pointing to the arc weld and the damaged brake line. https://www.turbodieselregister.com/user_gallery/displayimage.php?&photoid=1643&width=0 https://www.turbodieselregister.com/user_gallery/displayimage.php?&photoid=1644&width=0
Any help would be appreciated. This includes part numbers!
Thanx guys,
Kevin
Thanx guys,
Kevin
