I want to say first that you guys are awesome and are the foundation that supports all diesel rammers. I bow to you. My problem: A friend of mine is blowing black smoke from his 93 2wd 3500 and it started suddenly and with out provocation. No, he didn't tamper with the pump and has maintained his rig adequately. He has been told various stories such as... "your injection pump is going out", and. . "You need new injectors"... I know some of you guys have been through this before, so... Here's what I have done.
First, I checked the intercooler connections.
then listened for air leaks under the hood(difficult, at best. )
I took a look at the fuel delivery shaft inside the pump and found no damage and a witness mark on the leanest setting. So, the pump wasn't 'tweeked'. He states that it blows heavy black smoke when he applies go pedal, not even mashed to the floor, but about half throttle and above. No noticable drop in performance either. I haven't found any obvious problems. Have any clues?
Any help would be appriciated, thanks.
Steve.
98 qc, 4x4, slt laramie, 3:54 ls diff, 2YG pkg, Kelsey trailer brake control, dodge running boards, diamond plate bed rails, silencer ring in the wife's jewlery box, bone stock. (for now, heh heh... )
Steve.
