Check the switch on the brake pedal. Since you had the hydro-boost replaced, you most likely need to adjust the switch. To adjust it, push the pedal down, then push the switch in towards the pedal, release the pedal. That should reset the switch to its proper location. as far as the parking brake, they probably have the cable too tight and the pedal won't return far enough to contact the switch.
