Can someone please help!!!!! If you have a 5 speed, ext cab, long bed, 4wd can you please get me the measurement from the front of the large balancer on the rear diveline to the center of the carrier bearing... I got front end stuck, and while trying to get out I broke the spiders in the rear end, and I believe the carrier bearing was somehow pressed on further than it should be. All of this has been repaired including the carrier bearing, but driveline is still hitting on the carrier bearing housing... I belive when they pressed the new bearing on they put it in the same place. I need this measurement, please help!!!!
