RSchwarzli
Over the last few weeks I have done the following to the 1990. I will mist them all here so if by chance one of them had something to do with it and I am overlooking It, you can pick up on it.
Hx35 from 1997 12v cpl 2174 180 hp pump
BD exhaust manifold
KDP
Changed timing the correct way. Now reads 1. 79 mm lift at TDC
a few new injection pump banjo bolt seals
Vacuum pump seal
Boost gauge
turbo drive pressure gauge
Just started it up, let idle for 15 min, go through the rpm range and when I gt to 1900 it continues to gain without any more pedal movement till I removed all throttle at 2900 rpm. Then it dropped back to idle.
I don't get it. I changed nothing fuel wise minus timing.
Am I missing soemthing?
Thanks!
BD exhaust manifold
KDP
Vacuum pump seal
Boost gauge
Thanks!
