I had a local transmission shop install a new clutch late last week and the thing won't release. Clutch company says it's a bad install, mechanic says it's a bad clutch. Mechanic has removed the new clutch to make sure he didn't do anything wrong, and it looked like it was installed properly. How hard can it be, right?
Symptoms: You can put the truck in gear, push in clutch, and start vehicle. Everything is fine. Then take vehicle out of gear, and go to neutral. After this, you cannot get the transmission in any other gear without turning the engine off, and putting it in gear again. Partial release... ...
The flywheel was refinished, very little was taken off... .
I would have done the job myself, but my real job and family commitments don't allow the time. I thought I would let the professionals do it and not have to worry about it... Ha! Now I have twice the worries as I did before.
Clutch company is sending another clutch (at my expense) and won't credit me for the first clutch until they get it back and bench test it. What is the chance that their "bench test" reveals a defective clutch? Slim to none.
This ordeal is not nearly over... . My hunch is that the next clutch won't work either, and I'll then own two of them.
If I hadn't been such a tight @#$, I would have been better off buying one from Joe Donnelly. This is going to be an expensive lesson for me. When it's all said and done, I will have spent enough to own one of the best clutches..... I hope you guys can learn from my mistakes.
