Engine/Transmission (1994 - 1998) HELP! Clutch won't disengage....
Engine/Transmission (1998.5 - 2002) Fuel Pressure
2nd Gen Non-Engine/Transmission HELP! 01 Control Arm Bushings
BigPapa
1995 2500 2WD. Came with an auto, converted to NV4500 @100K miles ago and put in an SBC Con-O. No problems.
Driving to work this morning I got stuck in stop and go traffic for about 30 minutes. Finally got rolling and when I went to shift from 3rd to 4th it didn't want to shift. Pulled over and the clutch will not disengage. Transmission is shifting fine. I can start it in 1st gear and "speed shift".
The master cylinder is full of fluid and the pedal feels normal.
HELP!!!:{ :{ :{
Scott
The clutch plate hub came apart and one of the springs came out. The springs and the part of the plate that broke off were wedged between the pressure plate and the finger springs. SBC is helping me out with a new clutch plate. :D
Scott
