HELP! Codes P0107 & P0642 2 days before vacation
48re testing
Any problems running the Edge EZ on a 04.5
I looked up the codes for these and they both relate to the MAP sensor. But does anyone know if it is the MAP in by the Air Box or the MAP in the intake. I figures this happens 2 days before vacation towing my boat 1000 miles. I did clean and oil my AFE air filter. I did here that sometimes messes with the Sensor on the air box. I did try cleaning it with brake fluid but that did not help. Any other ideas??? I reset the codes and it comes back immediately and it also runs like it is not getting fuel or timing. Also my clutch fans runs way to much.
Originally posted by AHutchison
here is a link to the codes that you are experiencing.
https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=64031
Also, a little off the subject, but where did you get your blow off valve and where at in southwestern ohio do you live?
I live in Miami Township just south of Dayton. Also I got my BOV from McMastercarr Industrial parts. It does not have a large volume of output when it blows but it seems to be enough to keep my boost in check.
www.mcmaster.com
Economy Brass Pop-Safety Valves for Air
• Set Pressure: See "To Order"
• Maximum Temperature: 250° F
Low-cost protection for compressed air systems. Valves are made of brass with a stainless steel ball. Ball is seated on a precision-machined brass seat. Seat is metal-to-metal.
Connections: NPT male bottom inlet and vented side outlet.
To Order: Valves are available at set pressures from 5 to 100 psi in 5 psi increments. Please specify pressure setting.
Pipe
Size Height Each
1/8" 1 1/2" 4772K2 $4. 89
1/4" 2 1/2" 4772K4 6. 87
Pipe
Size Height Each
3/8" 2 1/2" 4772K6 $7. 31
1/2" 3 1/8" 4772K8 10
FIXED!
Well I got it fixed today at the dealer under warranty. It was the IAT sensor. However it will drive you crazy in the book. Because they call the both a type of MAP sensor. The MAP sensor on the intake part# supersedes to the IAT sensor on the AIR BOX. They also told me that any kind of dirt or oil from the re-usable filters will damage them. I asked about cleaning them and they have never seen that to work. Once they get dirty they need replaced. However they are only about $50. 00 Part #53032649-AA. I still could not find the part # for the actually MAP sensor standing at the parts counter. They were baffled:rolleyes:
