Ok I am getting P0148, P0088 (RP above Max) and P0524 (Unknown). I have installed larger injectors and thats when the codes started. I have turned the Smarty down to #3. I have a bag o parts CP3 upgrade, do you think my CP3 is the problem?
Also my rail pressure at idle is 7,000ish and at WOT it is at 24,000ish I have not seen it over 25,000 and not below 6000. Max boost is 50psi. with HTT71/64/13.
Any help would be appreciated.
