I'm in the middle of connecting the map sensor on my 99 and the connector going to the sensor hooked right up. But the other side of the connector going to the original wire won't go.
I've tried and tried and it lacks the last 1/4" to connect. I've aligned it correctly, only three prongs so no biggy there. The pins all look to be correctly lined up with no bends.
What I'm wondering is if there is a set of bad harnesses out there ????
Am I missing something??
One side hooked right up so I should have the corect connector right?
Please help ASAP. My truck is useless and sitting in the driveway.
Thanks
Thanks
