DaveHess
I have a mis-guided friend with a Duramax who is having a starting issue. The initial turn of the key lights the glo-plug light, all gauges take a swing to the left. The glo light remains on for about 30 seconds. The truck turns over, seems to light then continues cranking. This process goes on for a while of him repeating the process and eventually the gauges swing to the right and she fires. Lots of white smoke while cranking and after initial light. He has replaced the glo-plug controller (BTW, I have no idea if this has glo-plugs so please interpret this to be whatever the Duramax uses) The truck is a 2005. I suspect a ground somewhere but you guys are way smarter at this stuff than I am. The temp here lately has been single digit to below zero single digit.
