2nd Gen Non-Engine/Transmission help: easiest wire for + ignition on source
2nd Gen Non-Engine/Transmission Rocks in hubcabs??
Engine/Transmission (1998.5 - 2002) Cool Twist Turbo
In the middle of my gauge install can't find an easy wire for pyro ignition on feed. The taping was gravy compared to fishing the wires through the firewall...
even went diehard: no boost bolt just tapped the intake!
TIA whoever answers this one>
Add one of these to your fuse panel near your driver's side door:
Add A Circuit
Get your test light and find a fuse that is on only when the ign. is one then take out the fuse and install the Add-a-Circuit. You will need to file the black a bit to get it to sit properly in the fuse location. You will see what I mean if you go this route, just compare it to a fuse to see where to file.
You can pick these up at autozone.
cya,
Casey
Another place to get an ignition hot only source is the radio. I am not a big fan of those add a fuse things... I can never make then work. Pull the radio unplug the connectors, and find the one that has 12volts + only when the key is on and you are in business.
Add A Circuit
cya,
Casey
These are really handy. I used one for the lights on my gauges. It can get kind of crowded in the fuse panel if you use several of them though. But they made finding the right circuit really easy.
