Engine/Transmission (1998.5 - 2002) HELP Edge-EZ died
Engine/Transmission (1994 - 1998) Radiator Question
Engine/Transmission (1998.5 - 2002) The Dog Lives Again
I finaly got a little breather from all the overtime at work yesterday and decided to take care of the over due maintaince on my truck. Changed oil, fuel,air filters,greased front steering gear. Checked front and rear diffs. Jumped in and took her for a spin. :--) Man, somethin ain't right. Then it dawned on me, this thing's got no guts. I think my EZ has died:{ Was working great before, and I know it's just a coincidence that it showed up just after some maint. Has anyone got an Idea? Do these things just die all at once? It's only about 6 months old. I'm feelin withdrawal pains!:( I have begun to like the" DARK SIDE" Iwanna go back.
Jelly,
Pull all the connections and clean them and put some new dielectric grease on them, if that dont work than send it to EDGE, they will take care of you, they have extra good customer service they stand behind their products all the way.
cheers, Kevin
The MAP sensor plug seems to be a common trouble spot, especially when messing around changing the fuel filter.
Try taking the MAP plug loose, spraying with contact cleaner, squirt a little dielectric grease into the plug, and re-attatch.
