Hi all...been reading all sorts of stuff on the web about this issue and trying to do my best to isolate the cause of the issue.
Wednesday night I started getting an intermittent set of warning lights and bells (most were ABS and airbag related) along with the typical gages fluttering and acting up. Initially this only happened during deceleration. It got progressively worse to the point that when I pulled into a parking lot to try to figure it out, it started to idle rough (exactly like it would do if you turned the key off and back on before it could fully shut down..it "hiccuped" so to speak.).
I got it home with progressively more errors, eventually losing control of my headlights, with the brights stuck on, no turn signals working, etc. After pulling into my shop, I turned the key back on and got the "no bus" error in the odometer.
I've taken a bunch of stuff apart, pulled all fuses, isolated batteries, etc. and can't seem to get the fault to clear. I'm worried it may actually be a bad IPM/FCM that may have shorted internally.
What it is still doing is the following.
So...any thoughts as to where to start with on the short to ground? My gut feel is in the headlights some place (ironically I just replaced the bulbs like for like with Sylvania Silverstars) but want to make sure i don't miss something else.
I replaced the crossover cable last year after some battery failures, and I continue to deal with corrosion, so am planning to replace the rest of the cables.
Thanks!
- Upon key on, truck goes through normal pre start routine with the lift pump and relays buzzing but no warning lights or bells, and after about 10 seconds the head lights come on full bright, and the "no bus" warning flashes.
- Truck will start and run but will stumble and hiccup
- Removing battery negative results in a spark.
- I've tested the voltage between the negative battery terminal and the negative battery cable...I'm getting 14v or roughly full battery value -> So clear suggestion there is a short to ground somewhere.
- If I remove the IPM power feed, this voltage drops to about 10V.
- I also have 10 V from the negative battery cable to a chassis ground with the IPM disconnect, jumps back up to 14v when I connect the IPM.
Thanks!
