I was driving home from a short trip to the store and the truck went sluggish on me. Has an automatic, seemed to be stuck in third. Had to manually dial in 1st to get away from the stop light. Then I noticed the GEN warning light, CHECK ENG. light, WATER IN FUEL light, TRANS. TEMP light, and WAIT TO START light were all on. The tach. and speedo were out. Overdrive is out. Also the one of the AIR COND. lines is iced up even though the unit is not turned on. The other circuits are normal. The truck temp guage is normal on the road. Can't find any blown fuses, other than an ABS pump fuse. Can anyone help me on this one?
'96 4X4, Quad Cab, rebuilt AT, Pac Brake, 4" exhaust,high flo muffler,Power Loc rear diff. ,454 gears, Off Road Tech front and rear bumpers, 12. 000 lb Warn Winch : : : : : :
