On my 99 I am seeing engine temps from 200 to 230. The problem only seems to happen when I'm making boost. . ie. . my foot in it during city driving. When I get it on the freeway and when the boost is low or none then it drops to normal of 190. If I pull my 5th wheel (8K) then I can really see the needle swing all the way over to right. The EGT's are less than 900 under the load. The dealer replaced the fan clutch but that wasn't it, my truck being a 99 already has a 180 thermostat in it factory. Any suggestions would be greatly appreciated... I'm running out of options. . this doesn't make sense. The cooling system just isn't disapating the heat. Do these water pumps gradually go out??I thought they were mechanical so it was an all or nothing deal?
