I was checking my tire pressure today and noticed that the passenger side rear brake drum housing, was wet. i touched it and sure enough i got dirty oil on my finger. the inside of my wheel is lightly coated with it too, wich makes me think its either done this for a while or just started and its comming out fast.
questions:
Is this brake fluid or could it be from the axle/differential?
The brake fluid level in my resivoir was bout an inch from the top, is that normal? too high? too low?
what could have gone bad, or caused a leak like this?
since its in the rear and not in the front near rotors or pads that do most of my braking, how concerned should i be?
questions:
