Engine/Transmission (1994 - 1998) Help for Friend's P-Pump
Engine/Transmission (1994 - 1998) Truck Won't Start
Engine/Transmission (1994 - 1998) KDP repair session
A buddy transplanted a Cummins into a 4-door GM dually. I was checking it out yesterday, and he asked if I could help him figure out why one cylinder seems to be dead. Being a 1st gen owner, I'm not much help to him on his P-pump, but here's what I can tell you:
He started it and it was obviously "loping" like it was missing a cylinder. By the way, he says it will still outrun his dad's 'stroke as is. :D While it was running, he cracked open the fuel line at the injector on #3. Fuel leaked, but the sound of the engine did not change. He cracked open #2 next. There was a change in the engine's sound/smoothness to indicate it was not firing. He has already replaced the #3 injector with a new one, with no improvement. He has swapped the new injector with an injector from another cylinder - no improvement. Then he swapped (with another cylinder) what he called a "regulator" which is located at top of the pump where the #3 fuel line attaches. Still no change. In my mind, the injection pump must be at fault internally. There was a noticeable difference in the pressure of the leaking fuel as he cracked the lines, with less pressure at #3.
Any ideas of what could be wrong? He is hesitant to pay the bucks to have the pump rebuilt (if necessary) at the local shop. He's interested in talking to someone else who could do the fix. I'd appreciate any help/experience you guys could pass on. :)
Fitz
That could be a number of things. Start with the easy stuff though... pull the valve cover and make sure the rockers haven't fallen off. Next, check the compression... you don't want to see below 350psi. If that's all good, it's something in the pump and it's gonna have to come off to figure it out. Could be the cam, a plunger, the rack pin... literally all kinds of stuff.
Thanks Kieth. I forgot to include that he pulled the #3 valve cover and checked the rockers and the valve clearance. He said it was set to spec. He didn't mention checking compression, but it seems apparent that #3 is not getting sufficient pressure from the pump to fire the injector.
Anyone interested in doing some pump work on the side?
