I was on a trip the other day and was travelling up Monarch pass( about 6-7 percent grade) and loaded with only a couple of bags the usual trips worth of basic tools. I was going up in 5th gear about 55-60 mph. Going around the curves I would slow to about 45-50 and then accelerate lightly back up. I turned the radio off to listen to the sweet sound of the Cummins and SURPRISE, it was making a strange noise. It kind of sounded like a tire air leak that would start slow and then get faster. I noticed the boost guage would go to about 16psi and stop and flutter. I normally see 26 psi boost on a hard pull. It would not go over 16 no matter how hard I pushed it. I backed off a bunch and babied it down the other side. On the flat again a few minutes later I laid into it again, 26 psi and pulling hard. Any ideas from anyone, I am thinking probably the rubber intercooler lines or the wastegate hose. I haven't found anyholes or loose clamps though. If it helps it sounded like it was coming from the passengers side. Thanks.
