HELP!! GEAR/Bearing Noise/vibration with brake shudder at stop.
I hope you can help me diagnose the problem with my truck,
Or help me to look in the right places.
The truck particulars are: build date June 03 6sp 4X4 3500 SRW
HO, ST w/manual T-case, 72,000 miles Bradford flatbed (1000 lbs)
So. West Fab. Front bumper 275 lbs (?) Stock size tires Cooper ST.
Anti spin rear 373 gearing. I can’t think of anything else relevant.
My road, 4 miles in and out to the hiway is sometimes muddy
or slick so 4x4 is engaged both in and out daily, mostly anyway.
The sudden onset of the vibration/noise rather scares me as well as the brake shudder.
Notice it waited till right after 70,000.
The noise is rather like a pulsed zzzz zzzz zzzz zzzz zzzz and worse on deceleration
than acceleration. Almost feels like the ring gear/pinion when you let off the fuel.
It seems worse when cold and is speed dependant not engine speed related clutch in or out.
The worst speeds are 65>40 mph. ;
I CANNOT determine front or rear, ( I’m high freq deaf which doesn’t help)
I don’t feel it in the gear shift or T-Case lever
I can barely feel it in the steering wheel while lightly holding with 2 fingers
But I hear it and feel it none the less.
There is a pronounced shudder when applying the brake the worst speeds
Are 40>10 or maybe less. Not the ABS (it was slick yesterday and the ABS
Actuated and it is a very fast buzz) this is more like if you hold your tongue
to the roof of your mouth and exhale though your mouth.
Pads and rotors “Look” fine as best as I can tell at least 30+ % or more pad,
No scoring or nasties on the rotors that I can see.
I checked the diff fluids and their fine I would have checked the transmission but
don’t have the plug tool I’ll get one and change all the fluids in the truck.
I’ve spent time on bob is the oil guy site and know what fluids to get.
I spent over 15. 00 at the car wash washing off the accumulated mud
Off of underside of the truck to see better (the mud was pre-existing
By a long time prior to the sudden onset but the truck seemed
Much better on the way home but the problem re-manifested
Itself the next day. While hauling 1400lbs of hay home (return trip)
It was much less noticeable with the weight on the truck I think it was
still there though. I was driving very carefully with the big round bale
so couldn’t tell much.
Ive read lots of posts on front hubs, u joints, ball joints, etc…….
I jacked up the truck and spun the wheels, looked as much as possible
Reefed on the front wheels to sort of check ball joints. Looked at the u
Joints, mostly just looked but was on gravel so didn’t get too carried away
The tires were left on as I’m short on good surfaces to work on as well
As time and the tools I want for this type work.
I plan on getting all new u joints, ball joints, and I’m worried about the
Front hubs now. But this takes time and money both of which I’m short of, as well
As a turn in the weather to sub 0 temps.
I had planned to drive it Cheyenne this week or next to meet a fellow TDR
Member and pick up a set of Rickson wheels, but is 250 miles each way
With some pretty lonely territory on the way with a leaving and then returning
in the dark. 500 miles round trip. And this has got me spooked and cash poor.
I do not own an alternative vehicle suitable for this trip and I don’t want to get stranded
100 miles from any town with a 400. 00 tow to nowhere.
I need some suggestions or solutions to help figure this out so my confidence
Is restored in my wonderful Cummins workhorse. BTW im 75 miles from any
Dealer not that I would take it there anyway. And don’t know of shop I’d trust
With my baby and wallet.
HELP
Rich
HELP
Rich
