A few months ago I asked for a friend about some fuel pump lift problems that he was having. Here's the scoop; a 1998. 5 one ton all stock . About 180,000 miles and somewhat abused by previous owner. hE had lift pressure problems with the original pump . I helped him get home with the replacement pump and then we did the Genos relo kit to the outside the tank pressure pump . All was fine for a short time then the pressure started to drop on the next trip so we then did a fass ddrp pump that was not up to snuff and was replaced by Genos. Then the new pump went south within a 1000 miles. We sent the pump in to be tested and was fine. The advice from Genos was that the tank must have a bunch of junk in it that is being sucked up into the intake tube and reducing pressure. So we dropped the tank and except ofr the sliding mechanism being worn there was no crap in the tank and every thing looked fine. Bummer. So the latest is that when he fills up and has to pull hard for awhile the pressure can fall to 1 to 2 psi. As the fuel level falls the pressure rises to 10 to 12 psi at idle and 8psi on a hard pull. He does have a fuel gauge. I can't figure it out but he is coming over monday am . Should I blow out the all the lines or what. Thanks for your help and sorry for the wordiness. Brett ps. when the pressure drops to the 1 to 2 psi he'll pull over and shut the engine off and then pressure is upto 8 to 10 psi .
