crack the injector lines on the side of the head, bump the starter, leave the key on while the lift pump runs. Once he gets a little bit of fuel to trickle out of the lines, try cranking the motor over while closing off the lines.
Be careful, no fingers near the lines while they are open.
Once it's running, if it's idling smooth you're done, if it's rough, crack each line for a second or two while it's running.
That should get her going.
Matt
