Loosen the banjo bolt on the line that runs from the fuel filter to the injection pump, do the starter bump till you get fuel to that point then tighten the bolt and try to start, don't grind trhe starter more than a few seconds. If it doesn't start, then you need to loosen about three of the nuts where the high pressure lines go to the injectors, turn engine with starter a few times and fuel should appear at the loosened nuts, tighten nut and truck should start. Of course if the lift pump is not working, none of this will work. bg
