on my buddies 1990 the power adjust screw was turned in as far as possible with the steel collar on. we removed the collar and gave it 5 turns in,,,5 clicks clockwise on the star wheel and rotated the diaphragm a 1/4 of a turn clock wise. i have the idle speed screw backed the whole way off so that the linkage doesn't even touch the idle screw and the rpm's are very high. how do i control the idle speed with these settings??? i put the star wheel and diaphragm back to original position and set the power screw to 3 turns in so he could drive it and the idle is still a little high with the idle screw backed completely off. we drove it and the 3 turns of the power screw can definately be felt as an improvement but would like the give it a little more and be able to control the idle.
