Help me out if you can.
When I start my truck it will (not all the time) lope and shake the truck. Not sure how to describe it but it is like it is surging trying to stay running and if you give it throttle it will struggle to rev up. No check engine lights or codes are present or does the check engine light come on when it does this. If I shut the truck off and restart the truck will idle normally and run just fine.
Any idea what is going on? I am getting ready to load the camper and go out west and the last thing I want to do is breakdown.
I have all the current flashes that I am aware of and have only had to do routine maintenance on the truck. No issues other than this and like I said it is sporadic.
39,500 miles, Fuel filter needs replacing in 3000 miles, oil change reminder has not gone off.
