Archived Help installing Edge Comp
Archived New lift pump not lifting
Archived Help Help
I am in the middle of installing a Comp right now and I was trying to connect the harness to the map sensor but the connectors don't match. Am I not looking at the right thing or do I have the wrong harness?
the comp is year specific, the comp plug should be a triangle shape for the 2000 map sensor, if you have a different shape then its an 01-02 comp.
Yes, the sensor has a triangle shape and the one on the harness is more of a flat connector. Do I just need a different harness or do I need a totally different Comp?
