CRumsey,
I was looking over the wiring diagrams a little last night, and as I alluded to in my last message, I believe the "key" is in the ignition switch itself (no pun intended). There are 5 positions for that switch: off, acc, something, run, start. I think the computer judges what condition the engine should be in by a 12v signal at one of those positions. So, what we need to do is "fool" the computer into thinking the ignition switch is still in the "run" position. But we need to make sure, first. I will re-examine my wiring diagram when I get home from work, it should indicate what color wire you're looking for. Hopefully, no 12v signal at any switch position indicates "off". We will need to verify 3 items to be sure I'm thinking of it correctly:
1. There is a +12v signal at the "run" wire off the ignition switch when the key is turned to that position.
2. There is a +12v signal coming from the ISSPRO turbo temp monitor when the pyrometer indicates >300 degrees no matter what the position of the key is.
3. There is no signal anywhere when the key is "off".
These can be checked easily with a voltmeter, especially the temp monitor (since you have it sitting on your floor with all but that 1 wire connected). Like I said, I will check my wiring diagrams later today after work and let you know what I come up with.
And don't worry, I wasn't really offended or anything by your comments... I just wanted to make sure you don't think I was trying to "trick" you into the poorhouse!
