Engine/Transmission (1994 - 1998) HELP Installing SB clutch....got a ?
2nd Gen Non-Engine/Transmission 2nd gen for short wife?
2nd Gen Non-Engine/Transmission Lost key in ign. & headlights on
OK, I think I am second-guessing myself BUT, are the washers that come with the clutch kit that you use for mounting the clutch basket to the flywheel go on the outside (use as a washer) OR do you put them in between the clutch basket and flywheel (use as a spacer).
Just need some reinsurance about this. I think they go on the outside to use as a washer. Would hate to ruin a clutch because of my ignorance.
Justin
Gotcha, I appreciate it guys. I second-guess myself all the time. I got the transmission in now and bolted up and everything. Just need to figure out how much torque to put on the transmission bellhousing bolts to the flywheel bellhousing.
Justin
